Welding Header MIG Settings
发表于 2021-8-31 23:34:46 | 显示全部楼层 |阅读模式
Hello, I am looking for advice on welding this header shut,  attached are some photos, I will sand them down but I am looking for advice on what settings to use. Ive read to use high quick heat and sorta zap it almost as you would tac something, anyone have any advice on getting this done right and not making it worse?The mig is a 120 V ya219Thank you for any help Attached Images
Reply:These kinda jobs usually require a high frequency beam pre-heat before using the zap setting. Does your MIG have a high frequency beam pre-heat setting?Last edited by joedirt1966; 09-03-2010 at 12:26 PM.
Reply:Here are the stats* Primary volt  120    * Phase  single    * Frequency   60hz    * Features variable wire speed    * Variable heat settings    * Adjustable spot  Stitch weld mode knob    * Adjustable spot weld time knob    * Adjustable stitch weld time knob    * Adjustable weld interval stitch knobIf not any other way to accomplish a fix?  I think i have another welder that you put a long stick in it (TIG?)  but i hear that is not an easy weld to do. Also have a torch thing that i use to bend metal a mixture of two big tanks that gets me the blue flame, ive seen someone weld with that as well.
Reply:Originally Posted by joedirt1966These kinda jobs usually require a high frequency beam pre-heat before using the zap setting. Does your MIG have a high frequency beam pre-heat setting?
Reply:took em down the street 75 bucks and all good to go...worth the no hassle thanks for the advice.
Reply:Thanks..Glad it worked out for you.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-26 08:26 , Processed in 0.097117 second(s), 18 queries .
