Best TIG welder employers?
发表于 2021-8-31 23:34:44 | 显示全部楼层 |阅读模式
I've learned to TIG weld and am searching for employment. Aside from sheet metal fabricators where should I be looking for a job? What sorts of businesses hire TIG welders?
Reply:Aluminum boat manufacturers, machine shops, titanium sporting good manufacturers. These all generally pay fairly low. If you can weld pipe, look in to the pipe trades at UA.orgUA Local 598
Reply:Where in the US are you?Check Craigslist for job postings in your area?I'm the DC Metro Area and in the past few weeks there has been several job postings for TIG welders and welders in general.  I think some of the shipyards around Norfolk must have projects.  I think pay in this area is 16-18/ hour?BrianLincoln Mig 215Miller 211Victor Torch SetMiller Maxstar 200SDMiller Syncrowave 250DX Tig runnerMiller Trailblazer 302 running on LPMiller Extreme 12 VS SuitcaseEllis 1600 BandsawMiller xmt350 CC/CVLincoln Vantage 300
Reply:Aerospace industry uses alot of tig welding.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Insterno, you might get more ideas if you put your location on your info. Lots of aerospace shops in the Seattle area. Many small outfits and then there is Boeing.UA Local 598
Reply:Thanks, I'm in Orange County CA
Reply:Originally Posted by insternoThanks, I'm in Orange County CA
GMT+8, 2025-12-26 06:20 , Processed in 0.123490 second(s), 18 queries .
