Hi everyone, I figured this might be the best place to ask this question. I want to make one of these for a friend and I was wondering if anyone here has ever built something similar? What would be the best way to bond the glass to steel? Im figuring ill just get thin strips and custom bend each piece in a small break. Anyway I think they look cool, if nothing else this might give someone else a cool project idea Heres the link: http://scoreandsolder.com/#1251349/quartzMikeYou miss 100% of the shots you never take - the great one
Reply:what kind of steel are you going to use '' flat or round ''Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Its going to be flat steel that I'll break to the proper angles.You miss 100% of the shots you never take - the great one
Reply:Those look very similar to what a friend of mine used to do with stained glass. He had a copper foil "tape" that he applied to each piece of glass and then soldered them together when he made lamps. You can probably find exactly what you need at a shop or site that sells stained glass supplies. Mrs Zap or Wello can probably make some suggestions here as well since they do stained glass work..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:i built a frog terrarium with aluminum angle and lexan i got so 3M double sided emblem or trim adhesive get the one that is gray in color cause it is a close rubber cellulose stick it to the metal then assemble the pieces and i would fill the mating edges with a epoxy resin .Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:no steel there ..its stained glass but using clear glass, either foil tape and soldered over or lead channel that holds the glass and then soldered...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it... |
