'47 CJ2A truck.
发表于 2021-8-31 23:34:43 | 显示全部楼层 |阅读模式
This is the first of two CJ2A's I am building. This one is the truck version. ( The other will stay mostly stock.) It started off with a frame I bought.Found out later it is a '60 CJ5 frame that someone extended the middle 2 feet and added 30 inches to the rear.I cut the 30 inches of the rear...I had a very rotted out CJ2A tub, so I did a test fit.I cleaned up the frame and added 33 inch tires that I had...Here it is sitting next to the stock CJ2A frame...Here is the tub that I am using...The floor is already cut out to be used in the one behind it.Here it is now.Everything is loosely fitted so I can get a rough idea of where I need to put the hat channels.I am using a small Lincoln to piece the body together and recycling as much as I can off the 2A tub.Progress is slower then I want but hopefully will start picking up when the weather gets nicer out.'96 Cherokee 33's'02 Liberty '47 CJ2A'47 CJ2A truck
Reply:Cool. I have a 46 will be watching this build250DXMM251MM175225G plus 251D-1
Reply:Spent sometime in the garage today.'96 Cherokee 33's'02 Liberty '47 CJ2A'47 CJ2A truck
Reply:I, also have a '46 but with a 283 chevy. I need a trans with long input.The truck idea is really neat. Thanks man!Tim Beeker.
Reply:Frame came out looking very nice. Looking forward to this threads and the jeep's progression.
Reply:When time and the whether allow, I will push it outside and take better photos.'96 Cherokee 33's'02 Liberty '47 CJ2A'47 CJ2A truck
Reply:I like the look of the M38A1 windshield.Tim Beeker.
Reply:Originally Posted by tnjindI like the look of the M38A1 windshield.
Reply:Oops. Can a mod delete the post I made at 9:59?  The photo is way to large and it wont let me edit it....'96 Cherokee 33's'02 Liberty '47 CJ2A'47 CJ2A truck
Reply:Yep,I meant M38I had an M38A1, same drivetrain but with overhead valve motor.Tim Beeker.
Reply:Updates.Also finished the other rear corner.Unfortunately the tubing in the welding gun had a pin hole and was crimped badly. ( I bought the welder used.)   Have not searched yet but does anyone know where I can get replacement tubing? (3/1  3x5 )  I really do not want to spend the $$$ on a new gun if I can avoid it.'96 Cherokee 33's'02 Liberty '47 CJ2A'47 CJ2A truck
GMT+8, 2025-12-26 08:26 , Processed in 0.116365 second(s), 18 queries .
