adhesive help pls
发表于 2021-8-31 23:34:43 | 显示全部楼层 |阅读模式
Howdy  I need to attach 22ga stainless and 22ga paintlock sheetmetal to a sheetrock wall, any suggestions on a good  adhesive would be helpful. they will be subject to alot of heat, going behind a commercial cook line ...thx  : )
Reply:Get some of this..http://www.biosafe-inc.com/ag_adhesives.htm...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I've used liquid nails to mount stainless panels to drywall for kitchen equipment in the past (mainly in the Phoenix area). Get the commercial strength stuff (either heavy duty or the red project stuff), and skim it with a 1/8 or 3/16 v notch trowel. Should last till the restaraunt goes out of business
Reply:How about some finish screws into the studs?Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverHow about some finish screws into the studs?
Reply:Originally Posted by zapsterFinish "Screws?".....zap!
Reply:Check 3m products.  They have many spray adhesive for many applications.  Would screws be sanitary?
Reply:trying to avoid screws on the stainless....I will use panhead on the sheetmetal it will be covered up with pizza ovens ....thx all for the input ....heres a pic of what I started with will be completed in a few weeks Attached Images
Reply:sink is not level. Did you do the stainless work.  looks nice.Is that a trailer or box truck.  Those are popular these days.
Reply:Originally Posted by tapwelder sink is not level. did you do the stainless work.  Looks nice.Is that a trailer or box truck.  Those are popular these days.
Reply:Originally Posted by tapweldersink is not level.
Reply:Originally Posted by tapweldersink is not level. Did you do the stainless work.  looks nice.Is that a trailer or box truck.  Those are popular these days.
Reply:We've used PL Premium on 16ga. sheet metal to walls, not in a heat environment, though.Here's the the data sheet:http://www.loctiteproducts.com/tds/P...EM_ADV_tds.pdfBottom page has cured performance specs.Good stuff. Nice bit of flex. Get it right when you stick it, or your in for trouble! Should work for you. Screws: NO! Not good on a surface to be cleaned!! Even with caps!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:Originally Posted by DSWAlso refered to as trim screws. A "drywall" type screw with a very small head, usually with a square drive. Not the greatest pict but the closest I could find.
GMT+8, 2025-12-26 10:19 , Processed in 0.114401 second(s), 18 queries .
