Old Forney Welder
发表于 2021-8-31 23:34:39 | 显示全部楼层 |阅读模式
I've have this older Forney welder, it's a generator-welder/ powered by a winconsin 2 cyl egine.The model No 5KGV. On the engine shroud an ID plate has Model THD, ser.no. 3122241, size 3.25X3.25, spec.no. 168935. The welder: volts at max amp - 25;  max open CRT  volts - 84: Duty cycle 20 percent ; Max sec Amps 250. If anyone can help with source for Operator's Manual, and welder wiring skematic, it will be appreciated. I hope to get this working before Spring field work begins. Thanks
GMT+8, 2025-12-26 04:42 , Processed in 0.092463 second(s), 18 queries .
