Special welding process
发表于 2021-8-31 23:34:37 | 显示全部楼层 |阅读模式
I have a customer that needs me to replace some sq. tubing that ruptured from freezing over the winter.It requires A500-C 2x2x3/6 sq tubingDoes this steel require special wire. They need it to be mig weldedTHANKSLast edited by FABCON; 04-04-2013 at 12:15 PM.Cody WernerFABCONwww.fabconwelds.com
Reply:Nope. A500 tube is just electric welded mild steel.Er70 series filler is just fine.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:thanks for the helpCody WernerFABCONwww.fabconwelds.com
Reply:FYI You would be hard pressed to find any Hollow Section Steel (HSS) that is not A500
Reply:Anybody know the difference between A500 and A513 ?P.S. Anybody who answers "13" gets
Reply:Its not the A500 its the -C that is uncommonThe common sq tubing at the steel yards is A500-BA500-C has a higher tensile strengthJust wasn't sure if it needed preheating or a harder wireCody WernerFABCONwww.fabconwelds.com
GMT+8, 2025-12-26 04:36 , Processed in 0.102477 second(s), 18 queries .
