查看: 13|回复: 0
dialarc or idealarc
发表于 2021-8-31 23:34:34 | 显示全部楼层 |阅读模式
i was looking at buying either a dialarc or idealarc 250.they look about the same to me.is there any advantage or disadvantage to either of them? i was going to buy new ,but there are a lot of used ones for sale 'so i am now considering used. are the old ones the same as the newer ones?        thanks for all answers
Reply:If you get an older Dialarc HF, it's also an ac/dc/hf tig welder, capable of welding aluminum.  Not the latest/greatest, but it does weld aluminum acceptably.  The regular Dialarc 250 is primarily a stick machine that can also do dc tig.  Without HF, it's worthless for ac tig.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-26 10:20 , Processed in 0.103404 second(s), 18 queries .
