Anyone have this Strong Hand WAC35-SW Welding Clamp
发表于 2021-8-31 23:34:28 | 显示全部楼层 |阅读模式
Thinking of picking it up.  Unsure of whether to get WAC35-SW or WAC45-SW.  Anyone have either?http://store.cyberweld.com/sthawecl3ax.htmlMiller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:I have the 35. It is very helpful when you really need someone to help or you want to clamp something together and re-measure or just look at something from different angles and think about what you are doing from different perspectives. Attached ImagesTxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:I have the 35 as well and love it.  I am a one man shop and you can't beat it for holding things in place nice and square while you tack them up.
Reply:I have one of them don't remember which one it is. One thing I find handy is to have a couple of pieces of square tube the same height as the base to keep the horizontal pieces level. I think its 1" tube to match the one I am using. That way setting it on a level table everything is sure enough square and you don't have to work to keep the bottom pieces level as you tighten the clamp.  The one I have will clamp at least 2x2" tube.
Reply:I have 4, they are priceless! Cut it, drop it in and burn it in. No more tacking and whacking.(Home)Miller Maxstar 152 (sold)MM211/spool gunLincoln AC 225C(Work)Dynasty 350Powcon 300STLincoln SP-175TWeldlodgic AWS150sWeldlodgic AWS300Custom Resistance seam weldersCambridge Vacuum EB weldersI smell something burning.
Reply:You can make similar, any size you want. You gotta supply your own clamps though... Matt
Reply:Strong hand tools while great pieces of equipment, they are a complete rip off for the little guy.  I hope they go out of business.  I personally make my own tools such as pipe clamps, modified vise grips and such.  They cost me only quarters, nickels and dimes, compared to 100-dollar bills of Strong(arm) hand tools.
GMT+8, 2025-12-26 06:18 , Processed in 0.176108 second(s), 18 queries .
