welding in the bathtub?
发表于 2021-8-31 23:34:26 | 显示全部楼层 |阅读模式
First off, yes. It is obvious I am single. LOLIt is bloody windy today and I have a little project I want to finish before I drive to work tomorrow, I have a Jeep, the doors are off, and my coffee cup won't fit in the console, so I want to make a hinge mounted beverage holder.I have the rings rolled, the straight pieces cut, everything clean and ready to tack up.So I figure what about doing it all in the tub?Its enamel coated steel, built in fume extraction and fire suppression.Obviously I would risk losing my cleaning deposit, and maybe catch my shower curtain on fire, by why not?Aside from UV reflection, any real risks?
Reply:I don't see any problem, as long as the tub is filled with nice cold water beforehand, almost freezing works best.
Reply:I was thinking filled with chlorinated brake cleaner would work better.
Reply:Originally Posted by Fnord5... I have a Jeep, the doors are off, and my coffee cup won't fit in the console, so I want to make a hinge mounted beverage holder...
Reply:Originally Posted by OldendumI can sympathize.  I had an old Toyota pickup with a stick shift and no power steering for years.  No radio and no beverage holder.  I found that on the commute home from work, I could hold the beer between my legs while I shifted or avoided some other nut job on the roads of NJ.  It did have a sliding camper window, so I could ditch cans into the back.  Don't want them rolling under the brake or clutch pedal, you know.
Reply:Don't laugh about the bath-tub. They build some low rent housing in my old home town, someone called the fire dept, smoke coming out a window, fire dept responded, bath-tub 1/2 full of charcoal, cooking 'dem ribs!REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:http://all-a-cart.comWelding Cart Kits and accessories
Reply:"So I figure what about doing it all in the tub?"Yes, a good place.  And on top of the washing machine with an unbalanced load of clothes on spin cycle is a hoot too.
Reply:Oh c'mon now! Back in the day before it got strict I could drink a beer, smoke a cigarette, shift gears and feel up my girlfriend at the same time! The only thing that changed now is it's coffee instead of beer till I get home! Gotta learn to multitask bro! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I figure I'll wait till the wind dies down.
Reply:Attached ImagesLongevity 160sx Lincoln 140 miglincoln magnum spoolgunVictor torch and regulators
Reply:Originally Posted by ZTFab
Reply:TaggedTA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-26 04:34 , Processed in 0.074066 second(s), 18 queries .
