Snap-On MM250SL Questions
发表于 2021-8-31 16:58:45 | 显示全部楼层 |阅读模式
I have had a used Snap-On MM140SL for over 10 years, and its been an excellent welder.It has done everything I have asked of it... 22g sheet steel, thru 3/8", some DC TiG, and Aluminum with the spool gun.Like most guys, as I have grown, I need more.So I just bought a used MM250SL... made good sense, as I have the TiG and Spool gun already.I have not welded seriously with the 250 yet, but I have a dilemma...Can the 250 do the thin sheet too, or should I keep the 140 for that?
Reply:i'd say yes. Welded quite a few mower decks with one at an ag shop that I worked at part time.
GMT+8, 2025-12-18 16:29 , Processed in 0.066074 second(s), 18 queries .
