built myself a cart for my welders too!
发表于 2021-8-31 23:34:20 | 显示全部楼层 |阅读模式
Since everone else is doing it figured id better also. Since I'm kind limited on space and often use both my welders and only have 1 plug in for them both I figured why not stack them so they take up less room. My old miller 35 and my everlast 256 I'm working on putting a couple casters under the bottles cause I'm afraid if I pull hard enough it could tip over.
Reply:Looks great! I like the idea of casters under the bottles. It might be fine without them but for what it takes the added stability is well worth it.Tom Hintz, publisherwww.newmetalworker.comLincoln Pro Mig 180Lincoln AC 255Determination
Reply:I like the design....Simple.....Clean......Elegant.Now it only needs paint.Blue or Green?
Reply:I'm afraid to paint it. As I always seem to weld stuff to them later on.
Reply:Originally Posted by jesusno2I'm afraid to paint it. As I always seem to weld stuff to them later on.
Reply:Excellent work!I say paint it! :-)
Reply:I have a 256 toomy cart is configured so the bottles are on the back under the big wheels.I have an extention cord attached to the cart with two receptacles on the cart one for each welder.  It tucks away under a cabinet next to the front door of my shophave funTom Attached Images
Reply:Nice work. Where did you get the straps that hold the bottles?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I just used some 1-1/2" X 1/8" flat stock and bent them around the tank.It is a two part strap with a bolt in the middle of the tanks to tighten them up.One problem is when I got refills they swap out the tanks and there seems to be 2 diameters for the same volume of tank.You could use chains but I would put a support bar between the tanks and hook the chains to that with a bolt to take up slack.I have since added a hanger for the cables on the other side,have funTomLast edited by acourtjester; 08-28-2011 at 11:29 AM.Reason: added info
Reply:Nice work man. Looks goodGo Cards!!!!!
GMT+8, 2025-12-26 04:34 , Processed in 0.099597 second(s), 18 queries .
