aluminum fuel tank stand
发表于 2021-8-31 23:34:19 | 显示全部楼层 |阅读模式
Had to put together a test table for generator engines. Needed a gravity fed fuel tank stand figured it might as well serve dual purpose and mount the starter switch there also.crappy cell pic of weld bead.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
GMT+8, 2025-12-26 06:14 , Processed in 0.074169 second(s), 18 queries .
