pvc pipe ?
发表于 2021-8-31 23:34:19 | 显示全部楼层 |阅读模式
iv been wanting to figure out what size pvc pipe i would need to take a 50 lb. can of 1/8 7018 excalibur and transplant it in the pipe. kinda like a big rod keeper tube sort of thing !MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:8" pipe should do itBuy American, or don't whine when you end up on the bread line.
Reply:thats kinda what i was thinking. the tin cans measure 6'' i beleive but they are square so 8'' pipe should be fairly close guess.just didnt know if someone had allready done this before.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:8" PVC and fittings are quite pricy. You might want to think about several smaller pipes instead..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:If a 50 lb can is 6" sq.(36 sq. in.), 8" tube is 50 sq. in., and 3 4" tubes would be 37 sq. in.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:update. 45lbs of 1/8'' excalibur will fit in a 6'' pvc.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Reminds me of that joke about the monkey at the bar that would "measure" olives and cherries before he ate them ... after having swallowed a pool cue ball previously. "USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I know that one! Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:You could get away with using 1/4" PVC, but it would just need to be longer.
GMT+8, 2025-12-26 06:04 , Processed in 0.217777 second(s), 18 queries .
