welded stainless for the first time today...pics inside
发表于 2021-8-31 23:34:18 | 显示全部楼层 |阅读模式
well just wondering if I might be able to get some pointers or tips.  I just got the tig welder and am slowly practicing/learning before I jump on my projects.This is 16ga 304 stainless tubing.First thing is I seem to have a bad problem with the arc flaring up real bright once in a while in a yellowish color.  Any idea what that may be?I am having a hard time doing the fusion tacks and actually getting them to stick. Any tips?  I've tried lots of different ways and i eventually just end up melting both edges and have a hole.Does anybody have any pulse setting recommendations? I was real real sloppy because I didnt take the time to lock down the piece or get comfortable before I started welding...mostly cause I was excited to give it a shot.   This was probably the hardest part of it all.Using a clear oversize gas cup setup from arczone on a ck 20 series watercooled torch1/16 2% lantinated or thoriated1/16 308 filler rodbackpurge set at about 10cfhtig nozzle set at about 20cfh55 ampsno pulseLast edited by darkostoj; 04-11-2013 at 10:53 PM.
Reply:Not bad at all!Looks like you don't need pulse. I use it as a convenience but can do without it. Keep at it!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by darkostojFirst thing is I seem to have a bad problem with the arc flaring up real bright once in a while in a yellowish color.  Any idea what that may be?
Reply:Those are awesome beads for someone starting out. As above, the flare may be your helmet or dipping the tungsten,  when I dip I get a sudden flare.  For fusion tacks, a tight fit up and a fast blast at high amps.  I'm no pro, but for .060 steel, I set my machine to the spot setting, .5-1.0 second, and triple the welding amps. Very short arc length and a blast.  Works for me.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
GMT+8, 2025-12-26 04:34 , Processed in 0.075309 second(s), 18 queries .
