Repair Case garden tractor axle with powder braze
发表于 2021-8-31 23:34:15 | 显示全部楼层 |阅读模式
I've been digging in boxes and found some treasures from about 1999-2000!This video is edited down from about 20 minutes. The torch is a Colmonoy mark7 with Victor 100 handle and is about the last torch size/handle combo before you have to manifold the fuel tanks.The filler material is just a nickel chrome silicon with some boron, very ductile and good for iron repair. The axle had been soaked a bit with a propane torch before brazing and the cool down was also done using a torch. The axle is actually made from some very good ductile iron but is a bit slender for a garden tractor this heavy.I've also attached some pics of the crack and finish braze after it was dressed up. This was a 1969 Case195 garden tractor (basket case) I picked up to fix for my dad as a present for Father's day 2000 and I have a crap ton of repair vids and pics so this may take some time to get it all together. I lost dad in '04 and have the tractor back now, but this is pretty fun for me!Matt Attached Images
Reply:Oops, I should have mentioned the first 2 pics show magnaflux then the crack opened after straightening. I did "V" the crack out before repair.Matt
Reply:I remember that repair. It has been a long time.  Good job.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I love to see repair stuff and how its done..
Reply:Thanks Irish & roadkill, the powder braze torch is a bit of an odd duck but it is dead easy to use.Matt
Reply:Originally Posted by Smith09A lawn mower is a machine that uses revolving blades to cut a lawn at an even length. After buying a tractor, it is necessary that you must learn how to operate it safely.Besides, you must read the given manual carefully to know the proper functioning.
GMT+8, 2025-12-26 04:34 , Processed in 0.098467 second(s), 18 queries .
