Acetylene bottle problem Help Please
发表于 2021-8-31 23:34:15 | 显示全部楼层 |阅读模式
I purchased a used acetlyene bottle this weekend on craigslist and i put the regulator on and had no pressure. I took it to exchange and they said it was full. but they only said that by how it weighed. Is there a way i can pressure up or fix it. Has anyone had this problem.
Reply:Did you, by chance, open the valve while the regulator was off, to see if any gas came out and thereby determine if it had any pressure and, if so, roughly how much?I suppose, if you just got it used,  there's always a chance it could be filled with water, or even concrete!
Reply:i did crack it open with it off and there was no movement or pressure release. Cant they pressure up on it do maybe release the valve.
Reply:If it has no gas inside but weighs more than it should according to the numbers stamped on the cylinder, then something is wrong.Acetylene cylinders need to be refilled under very controlled conditions so it can only be done at certain facilities. If the cylinder doesn't meet the specifications (as determined by examination and/or proper testing), then it can't be filled at all. Did you show the people at the LWS that it had no gas, and ask what might be wrong?Any chance you can get your money back? Sounds like you probably were cheated...although I'd need to know all the details to be sure, and I cant help if you were.
Reply:well unfortunetly i cant get my money back the oxygen bottle did work real good and the gauge worked good too. The only one was the acetylene bottle.
Reply:Their is no way cheap or easy way around it you have got to take it into LWS to have it checked and serviced to see whether the valve/stem is stripped or stuck, I've never seen one.If it has acetylene they may credit you the acetylene.What did you pay for it?
Reply:300 for full set bottles and torch
Reply:I would take the bottle down to local welding gas supplier, exchange it for another one and tell them of the problem at that time.  They will figure out the problem, as they are the experts on testing and filling tanks.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-26 04:34 , Processed in 0.128758 second(s), 18 queries .
