Convert or Build a Tank Rack
发表于 2021-8-31 23:34:11 | 显示全部楼层 |阅读模式
My MM200 came with a dual tank rack, but it takes up too much space and I dont need it for my purposes.I dont know what the dual rack will fetch on eBay.  Im figuring aroung $30-35 to make a single rack in steel.I can easily utilize the existing rack to make the single rack without buying any steel.So the question is, what would you do?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:I would be a new one. That way if you ever wanted the dual rack, you can just throw it back on.
Reply:I went with the conversion.  Knowing myself, I'd just hang on to the Dual setup forever.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:the duel rack from miller for the mm251 was $250.00
Reply:Originally Posted by ed macthe duel rack from miller for the mm251 was $250.00
GMT+8, 2025-12-26 06:04 , Processed in 0.107501 second(s), 18 queries .
