hobart hefty parts
发表于 2021-8-31 23:34:09 | 显示全部楼层 |阅读模式
Hey guys I have a Hobart hefty that needs a contactor. The only ones I could find cost more than the machine. Any idea where I could get one cheap or find a used one or something  Thanks  Firedupmiller bobcat 250 ntsouth bend metal latheClausing verticle millrikon 17" bandsaweverlast 250exharris oxyfuel set upspeedglass AD helmet with adflo power respirator.
Reply:The wire on the output side of it was loose and the extra resistance heated it all up and destroyed it. The whole unit does not work or do anythingmiller bobcat 250 ntsouth bend metal latheClausing verticle millrikon 17" bandsaweverlast 250exharris oxyfuel set upspeedglass AD helmet with adflo power respirator.
Reply:Have you found a contactor? Mine just went down. The LWS is having trouble finding one.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:I have 2 of these that I beat regularly, when they die I will not be repairing them, not many parts to be had these days.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:The board is fine . I just noticed the wire was hot after a couple beads. Then it must have broke loose cause it started working fine.  When we got the job done I tore it apart and the points were pretty melted. Attached ImagesLincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:http://www.ebay.com/itm/Hobart-Hefty...item2c6dd40457Took me 5 seconds. If that doesn't help, look at electric forklift contactorsLast edited by AMC724; 04-08-2013 at 07:03 PM.
Reply:Talked to the manufacturer, Found out the contactor for a crown forklift is one # different. Got one ordered today. Will let you know how it works.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Got the forklift contactor repair kit for 116.00 and modified it. Bent the bus bars on one side and cut off the extra from the other side. they aren't as long as the original but everything bolts up just fine.  Fired it up and works like it should.Went ahead and got the one off ebay just in case for a spare but will sell if somebody needs it. Attached ImagesLincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:The crown Part # for the repair kit is 115-631Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
GMT+8, 2025-12-26 04:34 , Processed in 0.095879 second(s), 18 queries .
