Toolbox design ideas?
发表于 2021-8-31 23:34:09 | 显示全部楼层 |阅读模式
I'm going to build some toolboxes for my truck. I need some ideas on how to fab the lip for the lid to seal against.
Reply:I prefer the gutter style door seal. You basically make a gutter all the way around the door opening and the door covers it. This style rarely leaks even if there's no foam sealing. On the other hand the recessed type doors that use the foam sealing nearly always leak.  More pics further down on this post.http://weldingweb.com/vbb/showthread.php...058#post394058Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I've used 3/4" x 1/8" angle  pie cut and bend as nessesary.  I basically copied the way my JOBOX is done because well...it doesn't have silly foam and I've never got wet tools from a jobox on a jobsite.  Go check one out at home depot,tsp,or whatever. easy to copy. irish- the organization of your truck kills me everytime i see it! and running a 200le to boot!
Reply:Irish is right, I made mine the same as his and I have never had a wetness problem.
Reply:Irishfixit, thats a very nice setup. Do have a easy axcess hidden shotgun compartment in case you run into a Chupacabra in Texas?
Reply:Originally Posted by GrimI've used 3/4" x 1/8" angle  pie cut and bend as nessesary.  I basically copied the way my JOBOX is done because well...it doesn't have silly foam and I've never got wet tools from a jobox on a jobsite.  Go check one out at home depot,tsp,or whatever. easy to copy. irish- the organization of your truck kills me everytime i see it! and running a 200le to boot!
Reply:Yes, nice bed!Tools available but out of the way for using the flat bed.Where the screwdrivers and hammers are, how deep is that?Specail box behind the tool drawers?
Reply:Originally Posted by drujininYes, nice bed!Tools available but out of the way for using the flat bed.Where the screwdrivers and hammers are, how deep is that?Specail box behind the tool drawers?
GMT+8, 2025-12-26 04:34 , Processed in 0.092232 second(s), 18 queries .
