securing pipe stands?
发表于 2021-8-31 23:34:08 | 显示全部楼层 |阅读模式
I'm thinking about buying four pipe stands this Friday. They will be going on the back of my truck. And unfortunately I don't have a custom welding bed. I've seen people just push the v-head up to the Hoosier pole. But I'd like to be able to lock them as well. Any suggestions/pictures? Thanks.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:chain and lock is what i haveMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Weld a ring on them to run a cable/chain through.
Reply:I've been wondering why nobody makes the hoosier pole so it will drop down on the v and then lock in that position. If they are sitting on a vertical pipe they cant go anywhere.Lincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Originally Posted by propanehotrodI've been wondering why nobody makes the hoosier pole so it will drop down on the v and then lock in that position. If they are sitting on a vertical pipe they cant go anywhere.
Reply:i did just that. made hoosier pole tall enuf to stand jacks up undernieth it screw em up tight against then run chain through set screw handles. btw, i went a different route and my 4 jacks sit behind my machine on pass. side. made a plate with 4-3/4'' sucker rods standing up goin into bottom of each jack.iv got a hoosier pole for sale is what im gettin at.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Why beat around the bush, welderman?Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:i actually never thought bout selling it until i was halfway through my post ! kinda forgot i made the hoosier pole !MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
GMT+8, 2025-12-26 08:26 , Processed in 0.082111 second(s), 18 queries .
