Voltage/Wirespeed #''s ?
发表于 2021-8-31 23:34:05 | 显示全部楼层 |阅读模式
Where do you guys get your voltage and wirespeed numbers from ?Are the numbers on my MM180 dial knobs volts and inches/sec ?Somehow I don't think so and the manual doesn't either.L
Reply:You have a Voltage adjusting knobYou have a Wire Speed Knob- which is based on IPM- and is a % of the machines max wire speed10% Thru 100%Only real way to measure the Voltage/Amps on a machine without a Digital Display is to break out a meter and take some measurements.On a machine like the MM180 just go by the Chart and adjust accordingly. Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-26 06:32 , Processed in 0.094608 second(s), 18 queries .
