First project.
发表于 2021-8-31 23:34:03 | 显示全部楼层 |阅读模式
Ok I have a little cuby in my room that I was going to build shelving in and never got around to it. Im thinking that I will build a 1inch square tube shelf frame and use plexi glass for the top to make a really modern looking shelf for that cut-out in the wall. My question is... what is the cheapest type of steel that I can use to build this with? Should I use cold rolled steel tubing? I have checked with a few suppliers online and it looks like hot rolled steel is the choice and the longer you buy it the cheaper it is.... Do you guys think I would look like an idiot with a cordless angle grinder cutting a 24'er in half to fit on my truck? i did the math and its a huge savings to buy it long!Miller Diversion 165Rage 2 Chop saw
Reply:Definatley buy it long. Most places will cut to length for you. price is dependent on the size of material being cut. 1" square should be less than a dollar per cut. Just have them cut it to the length you need to get the peices to fit in what ever you're picking them up in and do the rest yourself. Check local suppliers. let them eat the shipping.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Also, make sure the cuts that they make fit your design. if you're buying 2 20' sections and your project needs 10 4' lengths. have them cut them at the 12' mark, that way you're not having to try to fit two lengths together later.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Do you think 16gauge is strong enough to fabricate a shelf out of? or should I go for 14gauge..... I just called and a 24' is gonna be like 26 bucks. thats with like a cut in half too.Miller Diversion 165Rage 2 Chop saw
Reply:Really depends on how much you plan on putting on it, and what you plan to use to weld it.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:well I will only put light objects on this shelf like bottles of cologne and other things maybe some ball caps on the bottom shelf, keys just a kind of out of the way shelf. I plan on tiggin this shelf together seeing thats the only machine I have right now.Miller Diversion 165Rage 2 Chop saw
Reply:I know where your road is anyway...Across the street from Danny's Pumpkin Seed Field......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Yeah that's right! I would love to come by and meet you zapster! I'm sure I could learn a boat load from you!Miller Diversion 165Rage 2 Chop saw
Reply:I am directly on Hiawatha..60 feet and I am in the water......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What a small world!Miller Diversion 165Rage 2 Chop saw
Reply:One of these Saturdays I'll have to drag you to the shop and give you tig 101 in 1 hr.You WILL be better....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Oh man I would love that!Miller Diversion 165Rage 2 Chop saw
Reply:Maybe in a couple of weeks..This Sat is taken..I am up to my ears in firewood to split...Musta did 7...8 cords this past long weekend.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-26 08:25 , Processed in 0.164459 second(s), 18 queries .
