Cheap DIY tung grinder
发表于 2021-8-31 23:34:02 | 显示全部楼层 |阅读模式
Hey I recently bought a cheap diamond wheel from ebay for like 7 bucks shipped to use an old dremel tool that my folks dont use anymore. Anyway I had been looking into a way to grind tungsten since I dont have a bench grinder. I had some scrap that I took from a friend and was able to whip up this neat holder for the dremel tool. Attached ImagesMiller Diversion 165Rage 2 Chop saw
Reply:Not bad for just scrap hanging around.... Its 1/4inch plate with a 1/8 flat bar with a  3/4 nut to thread the dremel onto. Im gonna paint it black. It works great with you place the tungsten into a drill chuck and spin it while grinding!Miller Diversion 165Rage 2 Chop saw
Reply:That's pretty cool.,.
Reply:That's one way to get it done. Very Macgyver of you.
Reply:Simplicity at it's finest.
Reply:have u ever tried using a torch
Reply:Here is my cheap tungsten grinder.  Harbor Freight 3 1/2 inch bench grinder with the buffer side wheel modded to take the HF diamond 4" saw sharpener wheel (about $10)   a piece of 1/4" scratch resistant plexiglass added so you all don't give me  for no guard...this is nice for cutting off contaminated tungsten too.  and it does not need to be bolted down to use it..   Last edited by soutthpaw; 09-08-2011 at 06:46 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-26 10:04 , Processed in 0.159394 second(s), 18 queries .
