Take A Guess Time...
发表于 2021-8-31 23:34:01 | 显示全部楼层 |阅读模式
OK time for everyones favorite game.."Name That Part"I did not have a clue until I asked..Pics below..Pic 1..The sample part..Pic 2..The parts I welded...Pic 3..Torch with my modified cup and the good'ol "Bend The Tungsten" trick..Pic 4..The reason you need the tungsten bent..Pic 5..The reason you need the tungsten bent..Next Post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Continued...Pic 1..Top view..Pic 2..First pass on the outside..Pic 3 ..Second pass outside..Pic 4 Done..Pic 5 Done.These will have the holes put in later as in pic 1 of the sample piece..The welder was on "Kill"..3/32" Red..1/16" 70S-2 filler..Anyone care to guess what these go to???...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:lotta stickout... im gonna guess it is a nutmasher.
Reply:Oh thats easy... I got this one.Thats Godzilla's knee replacement parts. weld it like you own it
Reply:Originally Posted by weldbeadlotta stickout... im gonna guess it is a nutmasher.
Reply:Originally Posted by lewrayOh thats easy... I got this one.Thats Godzilla's knee replacement parts.
Reply:Impeller shaft for one BIG azz water pump.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Originally Posted by larpheadImpeller shaft for one BIG azz water pump.
Reply:so based on the shaft on the bottom it spins or has something spin around it. It has large holes in the flanges. these could have two purposes, bolt something on solid like afformentioned impellor, or they could be use as pivot points for some sort of grapple device, or armeture. Is that a tapped fitting on the shaft in the "parts I welded" picture?I'm going to go with central pivot for an ammusement park ride.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Drill head?
Reply:Originally Posted by ThorsHammerso based on the shaft on the bottom it spins or has something spin around it. It has large holes in the flanges. these could have two purposes, bolt something on solid like afformentioned impellor, or they could be use as pivot points for some sort of grapple device, or armeture. Is that a tapped fitting on the shaft in the "parts I welded" picture?I'm going to go with central pivot for an ammusement park ride.
Reply:Is it the center section of a 4 finger grapple?MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:upon futher reveiw. the holes appear to be located in such a way that they would interfear with eachother if you put a bolt through them. You might get away with a pin, but I think a bolt is out, unless one side of the hole is tapped.two fittings per shaft. an "intake" and an "exhaust". say for a hydrolic piston. though based on the length of the shaft, it's a fairly short stroke, if thats what it is.Also, knowing that you have access to a VERY large Lathe, and because the original part shows no sign of "bearing wear". I wonder if the polished parts on the new shafts are due to spinning on said lathe, and not due to use of the mechanism.now, why two? Also the design of the base is different from the original, and both the original, and the new parts are fairly rough. The original appears to be a cast single piece. where as the new parts have some nicks and cust from grinders and such. so it isn't something that people are going to see regularly. it just needs to get the job done. not be pretty.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by Brink, M.E.Is it the center section of a 4 finger grapple?
Reply:A grapple would fit if the shaft is a hydrolic piston. but then, I doubt Zap would have to ask what it was if that were the case. A drill head wouldn't account for the fittings.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:SO CLOSE! I SAID IT! lol. We should play this game more often.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:It's part of the grapple that the 4 "Clamshells"? go to.....(There are alot more parts to this)..that go to a catch basin cleaning truck..This thing is swimming in crap all the time.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I just now got around to reading this post, but soon as I saw the first part, I was like, hmm that sure looks like a small orange peel style grapple center.  Guess I was right, oh well someone beat me to it.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Did you make the head (and weld it to the large shaft)? I see machining marks for a steady rest close to the head? If so, how did you weld it? The base plate looks to be 1.25"+ thick, how many passed did that take ya?Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Originally Posted by zapsterIt's part of the grapple that the 4 "Clamshells"? go to.....(There are alot more parts to this)..that go to a catch basin cleaning truck..This thing is swimming in crap all the time.....zap!
Reply:Originally Posted by natesuehrA giant one of these?
Reply:Having a good friend that  builds and restores Carousels, It  looks like the top pivot of a carnival ride,  carousels have way more connection points unless it is a small single row carouselhelped him build and install this one in Elk City, Ok.Last edited by soutthpaw; 09-08-2011 at 08:52 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by zapsterNot quite..One of these.....zap!
Reply:Originally Posted by JohnRDid you make the head (and weld it to the large shaft)? I see machining marks for a steady rest close to the head? If so, how did you weld it? The base plate looks to be 1.25"+ thick, how many passed did that take ya?
Reply:Very nice lokking work Zap. Very nice welds. People like you that can TIG like that just aggrivate the #$@! out of me!StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!Why such small filler?  Didn't you have to feed that like crazy?__David Hillman
Reply:You know I would not have TIG'd that.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:After reading many of your posts i wonder why so much tig? Many of the parts you do seem better suited for other processes. Just wondering.
Reply:Tig is more fun. lol!Admit it, you took a whiff of the sample part.www.thefusionsolution.com
Reply:Originally Posted by speedfreak87Tig is more fun. lol!Admit it, you took a whiff of the sample part.
Reply:Originally Posted by Eric CAfter reading many of your posts i wonder why so much tig? Many of the parts you do seem better suited for other processes. Just wondering.
Reply:Originally Posted by David HillmanWhy such small filler?  Didn't you have to feed that like crazy?
Reply:Originally Posted by zapsterYup..Much better penetration.....zap!
Reply:Originally Posted by sn0border88
Reply:Don't we all try for the most penetration? pun intended.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by zapsterI would actually love to see YOU attempt anything like this..We would all get a good laugh out of it more than likely.....zap!
Reply:Originally Posted by sn0border88I recently placed 3rd in a national collegiate welding competition, with competitors from over 40 other states.  I'll be alright. The welds look fine, my  was directed at the fact that you think a smaller dia. filler is somehow going to give you "much better penetration."  Complete and utter nonsense.
Reply:Originally Posted by zapsterSays who?I was going to use .045..Then what?...zap!
Reply:Whatever,,,You continue doing what you do and I will continue doing what I do...Results is the only thing that matters....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterWhatever,,,You continue doing what you do and I will continue doing what I do...Results is the only thing that matters....zap!
Reply:Originally Posted by sn0border88I never asked you to change your ways,  you can weld it with piano wire for all I care.  I just don't want bad information getting spread around by someone who should know better.
Reply:Snowboarder,  just cuz you win a college welding competition, it means only that u can weld better than most other college kids with limited experience.  In actual hood time and welding experience, you would be in Kindergarten and Zap would be a PHD.   I would be willing to bet if u competed against Zap he would win by a mile.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:so out of curiousity, assuming a welder was an expert with tig and with stick, there should be no strength difference for a part like this done with multiple passes, right?  And another side quesiton.. Are you so fast with Tig, that it is faster for you to tig than to stick + cleanup !??miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Originally Posted by jdchmielso out of curiousity, assuming a welder was an expert with tig and with stick, there should be no strength difference for a part like this done with multiple passes, right?  And another side quesiton.. Are you so fast with Tig, that it is faster for you to tig than to stick + cleanup !??
Reply:If you had a straight torch it would have been easier to weld the inside.
Reply:Originally Posted by welderman1If you had a straight torch it would have been easier to weld the inside.
Reply:So if I am understanding correctly, mild steel single vs multiple pass makes no difference for final weld strength, but higher strength alloy steels, single pass is stronger, and tig vs stick does not really matter?miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:That looks way to easy when do we get to see some pics of a chalenging bead?just joking of course. GREAT WORK AS ALWAYS
GMT+8, 2025-12-26 06:32 , Processed in 0.101972 second(s), 18 queries .
