Fishmouth calculator request.... sort of
发表于 2021-8-31 23:33:59 | 显示全部楼层 |阅读模式
I have a round tube (4.5 inch diameter) and I have a square tube (4" square).  Both have a wall around .098.  The round tube is vertical, the square intersects it at a 45" angle.  I have been out in my garage cutting and grinding and getting it to work, but I would like to make a paper template I can print out, tape to the tubing, and cut on a regular basis.  The fishmouth calculators I see are all for round tubing to round tubing.  Wondering if any of you have a way to create a template that will show me the exact cuts I need to make in both the square and round tubing to get this to work (will save me a bunch of time)?The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:I would make the template from the one you cut and fit.Wrap some thin cardboard (pop case or something) and trim it up. Dave J.Edit: but I think the cuts you are looking for are the parts of an ellipse that describe the cut through the tube.Last edited by MinnesotaDave; 04-22-2013 at 10:46 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I thought about it, but am not totally pleased with the current fit... looking for a little tighter.  I will have to make my template out of metal eventually.  I would like to use my plasmacutter to cut it out, and if I have a metal template I can get nice, straight lines/curves.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:You want to make cut-outs on BOTH the round and square tube??  Why not just notch the square tube so it simply "wraps" around [a portion of] the round tube?  Is it that notcher hole saws of this size are not easily attainable? 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Both as I am making another rocket stove (probably many of them) and I need it all hollowI am trying to do it via BobCAD, but it takes me forever to do stuff in there.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:BobCAD really blows chunks.....  I will try it via sketchupThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Seems as if the tools I need in sketchup are only in the pro version.... bummerThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:I might be able to help ya out.  Gimme a day or two.  Overloaded with work right now, hehe. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:That would be awesome, thank you....I measured the tubing... square is .078 and the round is .109The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Send me a picture of what you have done so far.  I just need to make sure I fully understand which section overlaps where before I try to find something for ya (something, either the round tube or the square one, must overlap on the other one even if the intersection is hollow, no?) 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by OscarSend me a picture of what you have done so far.  I just need to make sure I fully understand which section overlaps where before I try to find something for ya (something, either the round tube or the square one, must overlap on the other one even if the intersection is hollow, no?)
Reply:As Oscar said, given what you are trying to acomplish I would look into fixing a jig that allows you to make the cut with a hole saw... This will probably give you the cleanest look. Provided you have a drill capable of turning proficiently a 4,5" hole saw...Mikel
Reply:Good looking diagram, look up the math that goes with an ellipse.The cross section of a cylinder, when cut at an angle, is an ellipse.You will be able to sketch on the rectangle tube that way (top and bottom). Dave JDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Someone sent me a wrap around for the square tubing done in solidworks.  SinisterSandSports out on pirateThe Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Just cut the round tube at the angle you need and then place the 2 piece on the Square tube as your template to cut the Sq. Tube.Once you have the Sq. tube cut out place it against Round tube and mark it.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That is a good idea.  I didn't even think of that.  I miss some of the simplest things right in front of me often.  I will keep that in mind for the future.  Thank you.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Originally Posted by Broccoli1Just cut the round tube at the angle you need and then place the 2 piece on the Square tube as your template to cut the Sq. Tube.Once you have the Sq. tube cut out place it against Round tube and mark it.
Reply:The idea of cutting the pipe, scribing and cutting it seems simpler.  If you still would rather cut it you can by replacing the holesaw pilot drill with a 1/2" rod, necked down to go in the drill hole. Next drill a 1/2" guide hole in your square stock at the proper angle. The new guide rod will prevent the hole saw from chattering. It's going to be loud and slow, but will work. Attached Images
Reply:Originally Posted by blackbartThe idea of cutting the pipe, scribing and cutting it seems simpler.  If you still would rather cut it you can by replacing the holesaw pilot drill with a 1/2" rod, necked down to go in the drill hole. Next drill a 1/2" guide hole in your square stock at the proper angle. The new guide rod will prevent the hole saw from chattering. It's going to be loud and slow, but will work.
Reply:It's not easy. But I have done it. The shaft that replaces the drill holds the saw ridged enough.
Reply:Originally Posted by jdh239That is a good idea.  I didn't even think of that.  I miss some of the simplest things right in front of me often.  I will keep that in mind for the future.  Thank you.
Reply:Originally Posted by OscarSo I guess you have a solution then.  I was gonna work something out more like a template like you were saying, and I still might if there is a need.
GMT+8, 2025-12-26 06:33 , Processed in 0.093540 second(s), 18 queries .
