Looking at a lincoln classic 300G with 1800 hrs.
发表于 2021-8-31 23:33:59 | 显示全部楼层 |阅读模式
What is it worth? Does it compare to the 300D for farm use?ThanksJbmSent from my SGH-T889 using Tapatalk 2Lincoln 305GUnion Carbide TorchDon't Worry About the Mule~Load the Wagon!
Reply:Same machine but with a gas motor. The gas motor will start better in the cold. The gas motor will be fine for farm use.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Thanks for the help....Sent from my SGH-T889 using Tapatalk 2Lincoln 305GUnion Carbide TorchDon't Worry About the Mule~Load the Wagon!
GMT+8, 2025-12-26 06:33 , Processed in 0.090636 second(s), 18 queries .
