Miller syncrowave 300 (s)
发表于 2021-8-31 23:33:58 | 显示全部楼层 |阅读模式
I found this on Craigslist and was wondering if its worth the price they are asking. They want 1400 Obo and I think what you see in the pictures is what it comes with. I have only tig welded probably 30 minutes back in shop class in 2005 so I'm not a tig welder by any means but wanna learn, so would this be a good place to start? Also I read somewhere that the s in 300 s means that this machine will only do ac is that true?   Thanks a lot       Matt
Reply:Never knew about the (S) but I've seen a couple specials. Thought it would be cool to have one w/ the built in sequencer for welding out of position w/ a momentary switch. If you've got 100a, it's the last TIG you'll ever own.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:I have done a lot of dc tig welding and stick welding with that same machine. Good shop machine. Not portable and will take up some space, as you can see.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-26 10:11 , Processed in 0.096703 second(s), 18 queries .
