I have a millermatic 35, I made several welds and then it just stopped feeding. The drive motor is not turning. Has anyone had this problem, if so what do I need to do, or look for.thank you
Reply:Could be a number of things. Need a unit SN in order to look up the correct wiring diagram.How are you at electrical troubleshooting? Do you have a VOM (Volt/Ohm Meter)?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:where do I find the sn, it has a white front and spot weld module. I have beem very busy and haven't had time do any checking.thanks |
