Where can I go to get myself tested for 6g GTAW pipe/tube welding certification??
发表于 2021-8-31 23:33:57 | 显示全部楼层 |阅读模式
I'm wondering where in the Chattanooga,Tn/North Georgia area can I take 6g (gtaw) welding test?? How much would it cost?? (bend test or X-ray)Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Approved schools/testing facilities will be located on the AWS (American Welding Society) website.  Most of these facilities will have their own prices for testing and whatnot.  Take a look.  Here is the link.http://www.aws.org/w/a/certification/ATF/Matthew MortonTexas A&M '06Logsdon Seminary '13"Who Dares Wins""AFTF""WH2PH"SA 200 (Code: 5337)TB 302CP 302 w/22A Wire FeederMillerMatic 200Miller Syncrowave 200MillerMatic 252BurnTables 4x4 CNC MachineHypertherm 65
Reply:Why do you want to pay for a qualification test out of your own pocket?  Are you hoping that it will help get more job interviews?  ASME and AWS welding codes requires that each manufacturer conduct their own welding tests, so the independent certification would be virtually meaningless to a code shop other than to make your resume a little more attractive.
Reply:If he is contracting probably a good idea... Some companies require you to already have one... If you work for a coded shop and quit it doesn't follow you to the next... If you work in oklahoma you HAVE a oklahoma card... Out of state is not recognized... Just for anyone who might careA level 2 tornado can send an egg through a barn door... Two if ones open
GMT+8, 2025-12-26 06:33 , Processed in 0.092528 second(s), 18 queries .
