Purge gas for titanium
发表于 2021-8-31 23:33:56 | 显示全部楼层 |阅读模式
would c25 cause an world wide extinction event? it's a motorcycle exhaust...problem is I don't have double regulators for my argon bottle and I'm also low on gas, it's a 10 min job ...I learned the hard way it was Ti, customer said it's SS it looked a bit weird , all hell braked loose when I added a bit of SS filler I could see the factory spot welds were not purged or backed ...--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:That part would be trash.
Reply:No way.Co2 in any amount can break down next to the weld and introduce oxygen into the weld. If you don't have a second bottle and flowmeter, you could in a pinch add a valved "Y" and a hose to your existing bottle. But you have to be very careful to still have enough gas coming out of your torch when you actually weld. You won't be able to trust the flowmeter reading any longer. You could check that flow to the torch with a portable flowmeter. No matter what you do it will cost money.  I get my from netwelding.com. http://www.netwelding.com/prod02.htm Cheapest portable flowmeter is from here. http://weldingdirect.com/gasflowchecker.htmlJust remember just splitting the gas output with a "Y" is a no go, you have to verify correct gas delivery to your torch!Last edited by shovelon; 04-28-2013 at 07:22 PM.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Thanks guys, better do it right or don't do it.Funny how this small jobs cost me more then I make--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:ok.. so I went to the lws , got ripped as usual, ~50$ for a proprietary airgass quick connector mounted my integra dualflow meters on a regulator...guess you like pics as much as I do Attached Images--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:Awesome!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-26 08:25 , Processed in 0.073234 second(s), 18 queries .
