252 Ground
发表于 2021-8-31 23:33:55 | 显示全部楼层 |阅读模式
What is the awg size for the ground cable on a Millermatic 252 mig welder?Thanks,Jack
Reply:there are charts showing the size cable to use based on amps and distance. for a 252 amp machine you should use #1 cable for short runs and heavier cable over i think 150 or 200 feet..but look at the chart..too light and the duty cycle goes to hell..ground  cable isnt really a ground, either it or the cable to the stinger  should be sized the same, they are part of the same circuit...
GMT+8, 2025-12-26 08:25 , Processed in 0.139289 second(s), 18 queries .
