Project Tig Pedal
发表于 2021-8-31 23:33:53 | 显示全部楼层 |阅读模式
After a few weeks of diligent practice using the controls on the torch handle of my new Diversion 165, I decided to try my hand at making a foot pedal.  Finally finished it tonight, and tried it for the first time.  What a difference in control!  Now, I don't have to juggle the torch and controls at the same time.  Although I did see improvement during the time I was trying to learn, the torch controls forced me to hold the torch without any variation.  I realized a marked ease of use on the first bead I ran, tonight.I added a DPDT switch to the pedal, so I can start at high or low amps, thus allowing me to pulse at high amps as soon as the arc starts.  I, also, incorporated an RJ-45 ethernet jack on the pedal, same as the one on the front of the 165, so I can use a standard 14' shielded cable.I chose a wood base for the unit to simplify location and assembly of internal parts. Attached Images
Reply:Nice work! I like functional home brew solutions like this one!
Reply:Very Nice, I'd like to order 150 units.
Reply:what is the device ewith the cable in and out..a potentiometer?
Reply:Originally Posted by weldbeadwhat is the device ewith the cable in and out..a potentiometer?
Reply:How does the hot start/normal start switch function?This is awesome Weldordie, thanks for the post in my DIY foot pedal thread
Reply:Originally Posted by TaidenHow does the hot start/normal start switch function?This is awesome Weldordie, thanks for the post in my DIY foot pedal thread
Reply:very nice!  Great ingenuity!
Reply:This is great! I will be doing something similar and will add it to your post when I get it done! get a collection of DIY peddlesweldoride - about your hot start function. in what conditions would you want to pulse the maximum amperage like you described? I have tig welded a fair amount, but was never tough this technique.
Reply:Originally Posted by phyisisist777weldoride - about your hot start function. in what conditions would you want to pulse the maximum amperage like you described? I have tig welded a fair amount, but was never tough this technique.
Reply:Ah, that makes sense. Thanks!
Reply:Nice - I could see how that "hot start" feature could come in very handy!  Wish my TIG foot pedal had that.  I also like your string and pulley linkage design.
GMT+8, 2025-12-26 08:25 , Processed in 0.092372 second(s), 18 queries .
