Small welding table
发表于 2021-8-31 23:33:53 | 显示全部楼层 |阅读模式
Wanted a small table to move around in the garage. Attached Images
Reply:Tell us about this table... how big?, how tall? looks like 1 inch square tubing... on rear side of lower support it looks like you added a piece of angle iron... for future use? Bolts and nuts as leg levelers? How thick is the top? If you were to build this table again, what would you do different? I always have ideas for "next time".....  BTW, I like your table, I can see where it will come in real handy.Qualified & experienced at welding scrap metal
Reply:The top of the table is 18x26x1/4 with rounded corners and yes the frame is built out of 1x1 tubing. The height of the table is 33 inches with 7/8 nuts welded to the bottom and ground down with 2 inch long 7/8 bolts for adjustments. The angle is the start of a shelf for the bottom. I don't think its to bad for only having 10 bucks in it so far and thank you for the remarks about the table.
Reply:Your table is smaller than it looks, but a good size for most small projects. Do you have plans to add an electrical box to your table? $10.00..... it's worth that just in the cool factor. Last edited by little Jeep; 09-11-2011 at 09:52 PM.Reason: correct spellQualified & experienced at welding scrap metal
Reply:I have a small two by two table that I carried over to a shop where I am doing some sidework on roll cages.  I never knew how nice it was to have a full sized table until I didn't have one.
Reply:Electrical box is a good idea, i had not thought of that. Thanks for the idea  This table was  designed for small projects and also to be taken to one of the barns if need to. when i get a new shed built to keep my bike,four wheeler and zero turn mower in then i plan on building a larger table on the other side of the garage.
Reply:Originally Posted by rdchevy01Electrical box is a good idea, i had not thought of that. Thanks for the idea  This table was  designed for small projects and also to be taken to one of the barns if need to. when i get a new shed built to keep my bike,four wheeler and zero turn mower in then i plan on building a larger table on the other side of the garage.
GMT+8, 2025-12-26 08:26 , Processed in 0.092566 second(s), 18 queries .
