Help me locate an old post-homemade wire bender
发表于 2021-8-31 23:33:52 | 显示全部楼层 |阅读模式
Can someone help me find an old post by memory? Someone post a homemade wire bending tools he made using a horizontal press vise. He mounted three wheels on the vise. One on one side and two on the other side of the wise. There is a really good picture of it too.Thanks. I tried to search every which way but I can't find it.
Reply:I don't know the thread, but I save pics of projects I may want to look back on and I think this may be the bender you are looking for. All I kept was the pictures. Attached Images
Reply:Hey Johncan you reprint the annotations on the last picture so we know what is there???have funTom
Reply:angle is bolted to the aft jaw face of the vise and wheel bearings are bolted to the angle bearings and pulley must turn freelysteel plate is welded to the forward vise jaw and pulley is bolted to the welded plateidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by trapperjohnI don't know the thread, but I save pics of projects I may want to look back on and I think this may be the bender you are looking for. All I kept was the pictures.
Reply:Qdn - To me, this looks ideal to use as a coiler, for winding  long runs in a single direction, but somewhat tedious to use for single bends or for back-to-back bends with direction changes.If it's single bends that you're making, how ‘bout the type of bender that swings a rolling die in a radius around a stationary mandrel?Good Luck
Reply:have a folder full of pics i have saved.just added these and going to get one knocked up.
Reply:Originally Posted by prop-doctorangle is bolted to the aft jaw face of the vise and wheel bearings are bolted to the angle bearings and pulley must turn freelysteel plate is welded to the forward vise jaw and pulley is bolted to the welded plate
Reply:now go get a mill visethanks looks easy and handy GOOD weekend project once all parts gathered upidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by denrepQdn - To me, this looks ideal to use as a coiler, for winding  long runs in a single direction, but somewhat tedious to use for single bends or for back-to-back bends with direction changes.If it's single bends that you're making, how ‘bout the type of bender that swings a rolling die in a radius around a stationary mandrel?Good Luck
GMT+8, 2025-12-26 10:11 , Processed in 0.246465 second(s), 18 queries .
