A little sign work.
发表于 2021-8-31 23:33:51 | 显示全部楼层 |阅读模式
A local nursery needed a new sign so here's the design they came up with. I cut it from a sheet of 11 gauge hot rolled with my new Thermal Dynamics Cutmaster 52.I've really been wanting a Hypertherm but the LWS offered me a deal that I couldn't refuse.The Sign is ~12'-6" wide by ~3'-4" tall and has (2) 3/4" 16g sq. tube braces welded on the back. We fastened it with 3/8" countersunk wood lags through the siding into the OSB sheathing. For paint it's 1st acid etched with Coronado Sure-Prep III, then primed with Sherwin Williams oil based rust preventative primer, then painted with Sherwin Williams oil based low sheen black. The sun was painted with Liquitex acrylic enamel yellows, oranges and reds, then clear coated with low sheen acrylic enamel. Unless you're local you wouldn't know that the name of the nursery is a word play on the owners' name and the name of a local mountain called Max Patch.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Nice job on the sign. No problem with the 52.....a deal is a deal! At least it is one of the last ones built by US citizens!Here are some 1/4" stainless signs that I did a year or so ago....they are in front of 5 of Hypertherms plants in NH.  These were cut in my home shop on a Plasmacam cnc with a Powermax45.Jim Attached Images
Reply:putting that torchmate to work! nice.www.thefusionsolution.com
Reply:I love the top sign,  love that classic Appalachian look.  GREAT WORK!!Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
Reply:Hey his wife has the same thing as a tattoo on her inner thigh.  j/k...looks great man.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
GMT+8, 2025-12-26 10:10 , Processed in 0.103925 second(s), 18 queries .
