My tiny repair
发表于 2021-8-31 23:33:51 | 显示全部楼层 |阅读模式
A gearbox shaft with a pressed on gear broke in a Halloween animitronic.. thing..They gave it to my mom because it was broken. Took it apart, a shaft snapped at the E-clip shoulder. Looked like pot metal, was barely magnetic!..1/4" bar stockGear was about 0.075" thick3/32 Ceriated105A Pulsed, 65% pulse time, 50% background, 5 PPSI believe I used 309SS 3/32" because I wasn't sure what type of metal the gear was.. but it was crappy!I used my magdrill to spin it, poo man's positioner!Last edited by JohnR; 09-09-2011 at 10:08 PM.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Forgot to add, the second pic is just to show you the jig for making sure it was flat before I welded. I knocked the socket off and ran the end of the shaft flat (hard) against the 1x3 for ground so I wouldn't kill my bearings.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:No one ever likes my work Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:nice job!_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Good job on the repair and great idea on using your drill on the positioning  of the shaft.
Reply:When you said Tiny, you weren't joking.  Nice work.Qualified & experienced at welding scrap metal
Reply:Forgot to add.It was a bit tweaked after welding. It was still perfectly flat along the gear edge, but was lifted up on the edges (think cymbal). I tacked a dog to the table, and used some scrap tacked to the dog to pressure the edge back to flat using the socket as the stop. I think it's straighter now, than it ever was before! I put it all back together and it spins very well with NO gear noise (which couldn't be said for the original!). I think I lucked out.. the OD of the gear was too small to properly mesh in the gearbox before I spun it back to full size..Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Originally Posted by JohnRI used my magdrill to spin it, poo man's positioner!
Reply:using tools in a manner that was not originally intended. gotta appreciate inginuity.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2025-12-26 10:02 , Processed in 0.093249 second(s), 18 queries .
