DIY Foot Pedal
发表于 2021-8-31 23:33:51 | 显示全部楼层 |阅读模式
Here is a video of a new design foot pedal I made.The video shown two I have made the last is the new one.It may be a help to some.[ame]http://www.youtube.com/watch?v=283PgFZbHAA[/ame]have funTom
Reply:Very nice foot pedels
Reply:Now that you have designed them ( that's the hard part) they look fairly simple. Good job. Someone who knows what he's doing always makes it look simple. The mechanical part is pretty straight forward, but what size, value, pot is used and would it be the same for a tig pedal and a motor speed pedal?
Reply:nice job!
Reply:Originally Posted by acourtjesterHere is a video of a new design foot pedal I made.The video shown two I have made the last is the new one.It may be a help to some.have funTom
Reply:For the value of the pots, the original circuits determine that.  For the motor control the PWM I buy has a value like 10 to 20 k ohms. And I replace that with the same value with a longer shaft.  My tig welder had about a 50 k pot and a older tig had a 5 k pot.  So it’s not a one size fits all. If the original pot is not marked remove it from the circuit and check it with a meter.Papa I agree with the filter caps but since the original foot controller on my tig did not have them they may have been internal to the machine. The foot pedal cable would act as a big antenna so they must be in the circuit somewhere.  have funTom
Reply:Originally Posted by acourtjesterFor the value of the pots, the original circuits determine that.  For the motor control the PWM I buy has a value like 10 to 20 k ohms. And I replace that with the same value with a longer shaft.  My tig welder had about a 50 k pot and a older tig had a 5 k pot.  So it’s not a one size fits all. If the original pot is not marked remove it from the circuit and check it with a meter.Papa I agree with the filter caps but since the original foot controller on my tig did not have them they may have been internal to the machine. The foot pedal cable would act as a big antenna so they must be in the circuit somewhere.  have funTom
Reply:good stuff  right there ,    nice work>Innovations are what i leave behind for History
Reply:Very Cool..... I like the low profile design best.. thanks for sharingmike
Reply:Originally Posted by WeldordiePerhaps a shielded cable would eliminate the need for filter caps?  Nice job on the pedals.  Always nice to see ingenuity.
GMT+8, 2025-12-26 06:34 , Processed in 0.108159 second(s), 18 queries .
