Free design software?
发表于 2021-8-31 23:33:49 | 显示全部楼层 |阅读模式
Hey I have seen some posts on other sites about projects and some of these guys have had plans that were made on the computer. I was just wondering if there was a FREE and easy to use program out there to help in designing a project. If not I guess theres nothing wrong with a pencil and paper.....Miller Diversion 165Rage 2 Chop saw
Reply:a few people use google sketch up--it free and easyi use it to play with soap stone on metal or concrete floor wokrs good alsoidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by prop-doctora few people use google sketch up--it free and easyi use it to play with soap stone on metal or concrete floor wokrs good also
Reply:Im gonna look into it! Thanks guys.Miller Diversion 165Rage 2 Chop saw
Reply:again, google sketchup. Super easy to use. and you get to see what your project will look like (save the final paint color) before you've even marked metal. Has helped me determine that more than a couple of my ideas wouldn't work, before I put the time and metal into trying to make them.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:I also downloaded QCad, it's a free program as well. I also have Google Sketchup and it does some cool stuff.Lincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Google sketch up is the way to go for most all applications, but Sketchbook pro is pretty cool if you want to do more freehand drawing with a tablet. They have a very dedicated following which makes for lots of forum based support, and there many cool add-ons for doing more structured stuff.But it can't do what sketch-up does so it comes down to your own needs. One is free, and the express version of Sketchbook is free I believe so I guess you can play with both, but sketchbook really requires a tablet to get the full effect.
Reply:http://www.blender.org/ is free and always will be. Lots of youtube vids of it. Super powerful.Its hard to learn though.ThermalArc 161STL TIG/Stick (160amp)Lincoln weld-pak 100 (fluxcore)4X6 Enco bandsaw10" skillsaw with metal blade for 45degrees (works)4" grinderWeld for fun. Very rare I do it for Money.
Reply:A9cad is a free 2d program..  http://www.a9tech.com/a9cad i like sketch up but it doesnt save as a dxf or dwg..  dxf is pretty much the norm for most cad software.Last edited by brucer; 09-15-2011 at 06:13 AM.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Solid Edge 2D Drafting it's free http://www.plm.automation.siemens.co...response.shtml
GMT+8, 2025-12-26 10:02 , Processed in 0.212499 second(s), 18 queries .
