ideas for a satelite dish
发表于 2021-8-31 23:33:49 | 显示全部楼层 |阅读模式
I have an old 18"x15" satellite dish that I have a hankering to do something with. A search on the web revealed mostly garden uses.Any ideas?
Reply:well as for me i would make it into a directional wyfi antenna or a long range sonic ear with a uni mic lol but for garden i would say bird bathLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Big Soup Bowl????
Reply:fire pit?
Reply:Get some red & white paint.TargetBuy American, or don't whine when you end up on the bread line.
Reply:I have seen people collect broken up ceramic tile and put on them with a leg underneath and yes it makes a bird bath.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Originally Posted by llamafurfire pit?
Reply:parabolic solar heat collection
Reply:What he said, you'd need to get a bunch of the disco ball mirror squares and glue them on but it does work.  There's an instructable on how a guy did this with a much larger dish though I believe that you could do the same thing by removing the paint and then sanding to a fine surface then polishing it till its smooth.  The focal point should be about where the original lnbf ( eye ) was at at the end of the arm.Welding Supervisor Department of Corrections.
GMT+8, 2025-12-26 10:02 , Processed in 0.123406 second(s), 18 queries .
