The sandblasting cabinet that I built myself.
发表于 2021-8-31 23:33:49 | 显示全部楼层 |阅读模式
It only took me 16 years to paint it! Turned out alright though and works good to.This was the first thing I ever built and was in response to a need gernerated by me restoring and old Landrover while I was in my early twenties. Attached ImagesFletch
Reply:Seems like you only need to get a set of those fancy long guantelets to go with it and give it a try! How do you get the sandblasting noozle in there? Is there another opening for it I am missing? I don't see any in the pictures.Good job btw,Mikel
Reply:Got the gauntlet sorted and if you look really close (with a microscope) you can see the small hole for the airline fittings just underneath the right hand glove hole. the nozzle is the syphon type so air is all you need. the blasting grit is in the bottom of the hopper.Fletch
GMT+8, 2025-12-26 10:12 , Processed in 0.151478 second(s), 18 queries .
