查看: 13|回复: 0
Welding Robots
发表于 2021-8-31 23:33:46 | 显示全部楼层 |阅读模式
Do you think our postions will ever be turned over to Robots. I know GE already uses Robots to weld their new Turbines in the Plant in Schenectady. My rule of thumb is if its Repetitive, Dirty your on your way out. I think Robots will be able to do some jobs of welding but over all I think Welding would require the Human Manual System. What do some of you welders think?
Reply:Originally Posted by KevinL90Do you think our postions will ever be turned over to Robots. I know GE already uses Robots to weld their new Turbines in the Plant in Schenectady. My rule of thumb is if its Repetitive, Dirty your on your way out. I think Robots will be able to do some jobs of welding but over all I think Welding would require the Human Manual System. What do some of you welders think?
Reply:Originally Posted by VydunasNo human. You shall always retain your employment, we are not building your replacement as we converse. That would be absurd.Signed           -Weldotron 300 SN.4269013
Reply:That would be absurdabsurdabsurdabsurdabsurdabsurdabsurdabsurd
Reply:I work with welding robots everyday in a manufacturing environment and I will say that robots do take over positions, but they will never take over all the positions. And the majority of the times when they take over a position, they're taking over a position a human probably would not want anyway. If you have to build 300 widgets a day, every day, would you, as a welder want to weld them or let a robot do them? Robots are a great manufacturing tool, especially when talking high production numbers. Robots need someone to run them (at my company a robot operator makes more than a welder). As I said, robots do take some work, but they will never take all of it.
GMT+8, 2025-12-26 10:13 , Processed in 0.186764 second(s), 18 queries .
