Victor - which set is better?
发表于 2021-8-31 23:33:45 | 显示全部楼层 |阅读模式
Looking for an affordable set both of these are close in price, which would you get?Super Range 2" "Professional" 540/300 Tool Box OutfitCSR350D-540 Oxy reg CSR360-300 Acet100FC handleCA1350 Cutting 2-W-1 Welding nozzle25 ' of 1/4" Grade T hose...or the PerformerESS3 Series Edge regulators 125-540, 15-300T-Grade Hose 12.5' x 3/16"100FC Torch Handle CA 1350 CuttingW-1 Welding Nozzle...Is the Performer just the newer version?Just saw a Delux Cutskill Medium Duty outfit...Oxygen regulator # RC-2505with CGA 540 connectionAcetylene regulator # RC250 with CGA 300 connection(adaptor to CGA-510 provided)Victor genuine handle # WH270FC-V with built in flashback arrestors & check valvesVictor genuine cutting attachment # CA270-Vwith 90 degree head angle# 0 Cutting Tip# 0 Welding nozzle (0-UM-1)220 Grade RM hose 3/16"Last edited by bricot; 10-26-2010 at 12:51 AM.
Reply:the   one with 1/4" hose
Reply:So the newer looking regulator style on the performer aren't better?
GMT+8, 2025-12-26 10:15 , Processed in 0.104386 second(s), 18 queries .
