Millermatic 252 Jog Mode
发表于 2021-8-31 23:33:43 | 显示全部楼层 |阅读模式
My owner's manual explains the Jog Mode.  It doesn't explain how to turn it off.  Anyway I cannot find it.Can someone help me out on this?Thanks,Jack
Reply:the jog mode only applies when you are loading the wire in the machine. the machine apparently can sense that your machine is not arcing and goes into the jog mode. as soon as you finish loading the wire, put your tip and nozzle on, turn your gas back on, it should return to normal welding mode. at least that's what mine does.hope this helps you.Guy_48Welding is an art......Millermatic 252Lincoln SP175PlusLincoln 225 AC/DC
GMT+8, 2025-12-26 10:13 , Processed in 0.117546 second(s), 18 queries .
