TIG welding mild steel to 4130
发表于 2021-8-31 23:33:42 | 显示全部楼层 |阅读模式
Are there any problems TIG welding .063 sheet mild steel brackets to .035 4130N tubing? What is the best filler material to use?Thanks
Reply:Regular 70S-2 or whatever 70S you have..Preferably .045 for thin stuff.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I agree with zap 70s-2 should be fine.Ya gotta spend money to make money!
Reply:70s-2 is good. I just use .035 for that thin of stuff.
Reply:Cronatron 340T @.035 works, as well.
GMT+8, 2025-12-26 10:14 , Processed in 0.105911 second(s), 18 queries .
