Welding Command Center (AKA another welding cart)
发表于 2021-8-31 23:33:42 | 显示全部楼层 |阅读模式
Well I finally got all my equipment condensed down onto 1 large welding cart that was pretty much made of various pieces of metal I had laying around.   The wheel set is a Miller OEM set  From the older large transformer style machines, that I built the frame onto. has a full length pullout drawer and the rack for all the cables on the front had originally intended on adding it on the back but then I thought if its on the front its easier to grab the commonly used cables and Its now setup where the cables hang in front of the machine the go to.   I did not want them obstructing the drawer or blocking the access to get the saw out.  I also did not want a top above the welder because it makes it hard to get them off the cart if I need to.   TIG cooler is mounted on the rear.     Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:heck of a job PAW. looks pretty cool. i'll bet it took awhile to load all that up. buy the time you unload it and paint it blue or red you should be able to cut your load time in half lol. i didn't see the tow bar for pulling with the garden tractor. i don't see the fold up/down weld table attached to it yet.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Zokee-zoo Batman!  That is one Heck of a Welding Cart! "condensed down"??? Ok... where's the kitchen sink?... because everything else seems to be there!! And... where's the toilet? Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:What a clusterfux lol i hate cables everywhere.....I forgot how to change this.
Reply:That's saving lots of room.
Reply:DANG!  That's a lot of stuff packed in a small space. Maybe they'll cross breed and you'll wind up with your own version of a wire feeding TIG and a stick unit that gouges and lays in bead on the same pass. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:looks pretty darn heavy to me... i'd hate to pull it around, nice to have everything on one cart though..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Originally Posted by brucerlooks pretty darn heavy to me... i'd hate to pull it around, nice to have everything on one cart though..
Reply:I cannot place it, but I think your missing something...lol.Great build.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Originally Posted by ToolBoxTavernI cannot place it, but I think your missing something...lol.Great build.
Reply:Is there welders in there? Lol
Reply:The Keebler Elves have Side Jobs.  That or maybe Handy Smurf is running around there somewhereTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:thats awsome you have everything you need right there! by the way is that a cordless makita grinder on the ground? if so how do you like it?SIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:Every time I am cussing about tangled cables with just my torch, ground and foot pedal, I am going to remember those pictures and feel better. __David Hillman
Reply:Originally Posted by wd40prerunnerthats awsome you have everything you need right there! by the way is that a cordless makita grinder on the ground? if so how do you like it?
GMT+8, 2025-12-26 10:02 , Processed in 0.192120 second(s), 18 queries .
