Let's shorten and equipment trailer
发表于 2021-8-31 23:33:41 | 显示全部楼层 |阅读模式
I know sometimes you guys discourage trailer work, these are old pictures I came across from when I started this but better late than never. I will try to get up and snap a few of the 90% complete trailer. I need to do a total brake job and paint it.  Heres the run down, it's a Cross Country, 18 FT. already have an18 footer, so 12 is what she will be. Just a word of advice , I was disapointed to find the axles on this unit are barely legal for this trailer, they are a moblie home type axle with small bearings, and lighter tubes. Keep this in mind when you look at this brand of trailer, they do offer heavier axles but these are also out there. They are 4500 lb. X 2, in my book that adds to 9K , the trailer is rated 9,999?? MFGR says you got to figure in toungue weight, thats really bushy don't you think. Bought it for 500 cause the axle snapped at the rear wheel and that was missing. Now I know why. Attached ImagesLast edited by kolot; 09-15-2011 at 09:36 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:good luck with this thread lol...i wouldn't dare post a trailer project here...
Reply:Don't be scared bring it on. As long as your happy and it is done right then go for it.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Why shorten in? I always thought there was no harm in a bigger trailer.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:Swaggerwagon, That's funny, I agree but what the hell.  I shortened it because I tow with a crew cab and already have a long trailer that I haul my skidsteer and attachments and sometimes other things. Sometimes it would be nice to just throw the loader on a nice short trailer , light and more manueverable. Problem with this was I thought 500 was cheap, but when you figure the time and labor, I rewired all new LED lights, and probably will end up changing out the axles as well I will be 1/2 too 2/3 the price of a new trailer. Granted I will have better than when it was new but throw in a couple of tires and you see where this is going. Guess the problem is the the days of rebuilding and or fixing things just aren't as cost effective as they used to be. Will last a long time after it's done if maintained. Really no moving parts to a trailer frame so if you keep the axles, brakes , and tires up you can get a lot of miles out of them.  Will post more pictures as soon as I can take them.  Post note: I did weld a used part of and axle on the 1 that did shear off. Not great but I know it won't come apart. Problem is these axles are junk to begin with and I am suprised a well known MFGR. used them. I will wait till better ones come along or just buy new ones over time. They are a Dexter and it is not Dexter's fault, they are rated for a lesser application in my opinion. So beware if you are looking at trailers,externally they look the same but they have a smaller inner bearing and spindle diameter, it is less common to find parts in most dealers, have to be ordered. brakes are bolt on but light duty. When I called CC they stated they use these to keep the cost down, I replied likely to keep the profit up, they did not like that. Just being me.Last edited by kolot; 09-16-2011 at 10:32 AM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by Swaggerwagongood luck with this thread lol...i wouldn't dare post a trailer project here...
Reply:Having a trailer thread of my own. I think its safe to say, that if you're using the right procedures, and tools to do the job the guys here are just fine with trailer threads. It's when you start destroying the structure of a trailer, or use tools that are not capable of doing the job properly that they get vocal. lets see some more pictures.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Yeah, I didn't bring out the Miller Sidekick 115 volt for this project, SA200 for this. Trailer is up on my other piece of property, I'll try to get some more pics. tomorrow."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Since you are bobbing the rear, are you going to move the axles forward as well?
Reply:Originally Posted by GBMOriginally Posted by Swaggerwagon  good luck with this thread lol...i wouldn't dare post a trailer project here...
Reply:Hardware, that IS a good one....Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:I'm here all week.  Try the veal and remember to tip your waitress..."These instructions are at our present level ofknowledge. Legal requirements do not exist.Technical issues subject to change."_________________________________________Lincoln MIG PAK 180Lincoln AC-225
Reply:Hardware,That one hurt. I think I felt it in my toes.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Hardware,is that what the teacher told you your kid said? that's harsh.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Rather have a daughter in a whorehouse than a son in a steelhouse! Both can work a crack. I'll behave now."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by ThorsHammerHardware,is that what the teacher told you your kid said? that's harsh.
Reply:Nope, But apparently you thought I was.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:[you didn't think I'd get serious now did ya'?]
GMT+8, 2025-12-26 08:26 , Processed in 0.109347 second(s), 18 queries .
