Some of the work filling my time lately.
发表于 2021-8-31 23:33:38 | 显示全部楼层 |阅读模式
Here's a few shots of some of the recent and current projects. Many are still in progress and I'll try to get some shots to complete them.  First is a pic of the cement truck we redid last month. It's back now that they've got all the portland out of it so I can build a new frame for the mixer. The second pic shows the remains of the truck after they laid it on it's side. I put that truck on the front of the frame about 6 years ago and my splice held through the rolling of the truck so I guess I did alright.  The third and fourth are of a screw compressor we took apart, cleaned, and replaced the seal on. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Next is the welding trailer I just finished today. I built this for my dad using the bed he got for my nephew. It was done as cheaply as possible. I've still got to get the safety chains on it but other than that it's done.   The last pic is what I'm fixing to build my new portable shop/welding trailer out of. It will be a gooseneck when I'm done with it. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:This set of pics is of a spray rig we're working on right now.  The second pic shows the problem. We fixed the one in the third pic last year and put it back like factory. This time we're going to be changing things to a little more robust setup I hope. more pics of this coming Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Here's the last pic of the sprayer for now. This the factory setup for the pivot. The bearings are nowhere near big enough to handle the load put on these things in the field. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:This last set of pics might look familiar to those who've been around a while. I posted this unit last year under the eze out thread. As predicted it's back. This time I've got permission to fix it right. As you can see the bolts I put in it last year have failed. Well one of them did the other rattled out. Notice also the bolt they put into the transmission base is missing whether broken or rattled out I don't know. The spline is also worn but not much I can do with that other than make a new sprocket. There will be more pics coming of the sprocket and spline later. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I like the chainsaw in the back round of the pic . And the weld trailer you built is sweet nothing wrong with building that's laying around  .
Reply:Is that compressor off one of the HF Pancake compressors
Reply:I dont want to sound degrating, but your tire has a leak!Learning one rod at a time
Reply:Originally Posted by stihl91I like the chainsaw in the back round of the pic . And the weld trailer you built is sweet nothing wrong with building that's laying around  .
Reply:I went through your website, and REALLY like your sign (that's resting on your stove). May I copy it?For those that haven't seen it:Impossible:Done DailyMiracles:Require 2 daysNotice - ManagementMiller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Sure. Copy away. One of my part time helpers made that while I was gone. I'd told him I was going to make a sign saying that some day. So he decided to cut it out of that old plate for practice.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I love your work, you do some real crafty repairs on things I wouldn't know where to begin on.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Thanks. I do my best.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Here's a update on the pulling unit.  I had to make a new sprocket with spline. The spline on this transmission is obsolete so I had to go digging in some junk piles before I found one that was right. When I did it was in the form of yoke made to go next to a carrier bearing. The first shots shows me getting rid of what I could with the portaband. The second shots shows how far I got it down with the band saw. The third is bulking out the sprocket with the 2 1/4" drill in the drill press. The last two shots shows the new and old after my helper machined and pressed them together. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Here's how I stiffened up the transmission so that it would quit breaking mounting bolts. That's a 1 1/4" B70 grade threaded rod I used for a jack screw. I doubled the plate and made it fit the side of the transmission as close as I could. The pipe is 2 3/8" OD XXXX pipe with about a 1 1/2" hole in it. You can see the original jack screw below it. This was the only way I could figure to attach to the transmission in a strong enough manner. There just wasn't any bolts on the back strong enough to take the beating.   The second shot shows the sprocket in place. The third shows the broken mounting bolt after I removed it. Attached ImagesMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Nice work glad to see others with the same thoughts how to save otherwise junked pieces.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Thanks. Junk is usually all I have to work with.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:It ain't junk if it works when you are done... you never cease to amaze me... the pics are great.  If I were 40 I'd come over and get in the way trying to help... so great!   Do the folks around Shamrock have any idea how lucky they are to have U around?   I can hear them now  to the worried wife. > "Well yes dear it is broke bad, but I'm calling Irish and he's  coming around tomorrow early to take a looksee and get her running."Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Thanks. There's enough who know to keep me pretty busy most of the time (actually too busy a lot of the time like now).   Get lots of people in the way, trained more than one who went on to bigger things, changed the life of a few young people not always in a good way. Everyday is a learning experience both for the people who work with me and for me as well.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Irish. Just noticed the chain you are using, I've never seen one with the cotter keys in every link like that. Looks like they are all master and half links.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Dude, you build that chain entirely out of masterlinks?  That is a lot of cotter pins.
Reply:Relatively common in heavy chain. It's called cottered roller chain here's a link to some in the Grainger catalog (first place I found that I could link to).http://www.grainger.com/Grainger/TSU...er-Chain-1YGT8  Makes it much easier to break on a heavy chain like this.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Irish. Learn something every day, guess today is no exception. All the machinery I've worked on in 30 plus years never ran across it.Also some very nice looking work on all your projects.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Irish, nice work. Looks like alot of the stuff that comes into my shop, it makes you feel good when a customer pickes up thier job and says looks good I didn't think it could be fixed! keep up the good work.LarryMiller XMT 304 CC/CVSyncrowave 180 SDLincoln PowerMig 255XTTermalDynamics 52Lincoln 305GComlpete machine shop to back it up
Reply:Originally Posted by shortarcIrish. Learn something every day, guess today is no exception. All the machinery I've worked on in 30 plus years never ran across it.Also some very nice looking work on all your projects.Always love you threads and your work. I wish I had half your knowledge.If I lived closer I would pay you if you let me work for you.You get what you put in and people get what they deserve...
Reply:Thanks. It always seems like I'm paying people to learn. Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Paying people to learn isnt so bad. Its when you pay them and they do't or can't learn that really sucks.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:That's for sure. I tell everybody who starts that my most important criteria is the ability and willingness to learn.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
GMT+8, 2025-12-26 10:30 , Processed in 0.095803 second(s), 18 queries .
