H/F Cart Mod
发表于 2021-8-31 23:33:35 | 显示全部楼层 |阅读模式
It was raing cats & dogs this past weekend, so I had time to kill in my garage.I have two Harbor Freight welding carts that I picked up for less than $40 ea.BUT,......I never liked the fact that the top shelf (where the welder sits) has such a steep angle. I had to shim/space the cylinder out with a scrap piece of 2x6 because the welder was the same length as the shelf and the top, rear edge would touch the tank before going all the way back.ANYWAY,.........I modified / shortened the side rails, drilled a few holes and now the shelf (s) sit almost level. Attached Images
Reply:What size bottle are you running?HF 180 amp/240 volt Mig (cap mod)1987 Harley FLHTP (project)1990 F350 XLT Lariat S/C dually1990 S&S 11SC Cabover Camper2011 Ford Ranger S/C XLT
Reply:Originally Posted by desertscoutWhat size bottle are you running?
Reply:thanksHF 180 amp/240 volt Mig (cap mod)1987 Harley FLHTP (project)1990 F350 XLT Lariat S/C dually1990 S&S 11SC Cabover Camper2011 Ford Ranger S/C XLT
Reply:I modded an HF Cart too, Now you just have to make yours able to roll over something larger than dust....
GMT+8, 2025-12-26 06:32 , Processed in 0.114270 second(s), 18 queries .
