Test plate setup ?
发表于 2021-8-31 23:33:32 | 显示全部楼层 |阅读模式
Hi,I'm doing a 3G vertical open plate test on 16mm plate in a few weeks..I want to practice it at home properly but not totally sure of the correct measurement for the setup of the the plate.What usually is the size for the foot face..? Root space and bevel degree ? For 16mm plate.Thanks
GMT+8, 2025-12-26 08:26 , Processed in 0.107473 second(s), 18 queries .
